I am using an Atmega32-A microcontroller and an AD7798 external ADC. I am able to set the ADC registers and read back ADC values. I have written the following code:
statusreg = AD7798_8(0x40, 0xFF); // read STATUS register default value
Id = AD7798_8(0x60, 0xFF); // read ID register default value
mode = AD7798_16(0x48, 0xFFFF); // read MODE register default value
conf = AD7798_16(0x50, 0xFFFF); // read conf register default value
AD7798_16(0x10, 0x0010); // write Configuration reg = 0x0010. 2.5V range
value = AD7798_16(0x50, 0xFFFF); // read Configration register
if (value != 0x0010)
printf("unexpected conf setting %04x\r\n", value);
while ((statusreg & 0x80) != 0); // wait till ADC is ready
adc = AD7798_16(0x58, 0xFFFF); // read register
printf("ADC value is %04d\r\n", adc);
From the above code, I am reading the ADC values. According to the AD7798 datasheet and according to my configuration register setup, I have to find out the analog input voltage using following formula:
When the ADC is configured for bipolar operation, the output code is offset binary, with a negative full-scale voltage resulting in a code of 000...000, a zero differential input voltage resulting in a code of 100...000, and a positive full-scale input voltage resulting in a code of 111...111. The output code for any analog input voltage can be represented as
Code = 2N – 1 × [(AIN × GAIN / VREF) + 1]
where:
AIN is the analog input voltage.
N = 16 for the AD7798, and N = 24 for the AD7799.
I am getting an ADC value of 1EF2
(hex) for 0.6V analog input. I have measured using an oscilloscope. I have calculated the analog input voltage using the above formula and I am getting 0.15V. Here GAIN is 1, VREF = 2.5V. Which is wrong because I have to get 0.6V. I have converted resultant hex ADC value into decimal 7922
and also binary 0001111011110010
. My analog input voltage is varying from 0V to 0.6V. According to my analog input voltage my ADC output is also changing from 0002
to 1EF2
If I change the configuration register setup to any other setup like bipolar to unipolar (from 0x0010
to 0x1010
), at that time I am getting an ADC value of 0000
always. It is giving an ADC value of 0000
for any configuration other than 0x0010
in the configuration register.
More over, I am not able to understand what the following sentence means:
How do I properly convert resultant digital signal to an analog voltage?
Are my ADC readings right or wrong?
Why does my code not work for any other configuration?
