I'm working on a PCB design homework in PADS and I've come across a symbol that I have never seen (circled in red below). It is of a filled in rectangle with a triangle below it. I'm thinking it might be a type of switch but I'm not sure.
What is this symbol?
    \$\begingroup\$ Looks like a home-brew barrel connector symbol. \$\endgroup\$
    – Eugene Sh.
    Jul 22, 2019 at 18:28
That is a receptacle for a barrel connector. The symbol is supposed to imply circuit functionality. The following is not a standard symbol (don't use it!), but it should demonstrate the connection:
barrel
When you insert the connector into the receptacle, the center of the connector contacts the wide pin (the rectangle). The body of the barrel pushes the bent piece of metal out of the way, which remains in contact with the barrel because of spring tension.
In addition, when the barrel is inserted it also breaks the connection between pins 1 and 2. This can be used to detect if the barrel is inserted.
  • \$\begingroup\$ @M.H. Glad to help :) \$\endgroup\$
    – bitsmack
    Jul 22, 2019 at 22:24
