Can someone explain the basic process of flashing a bootloader to an HC08 based MCU? Specifically the MC908QB8.
If I understand it correctly, the firmware can be updated via serial while the chip is in-circuit but there is a separate process for flashing the bootloader?
  • \$\begingroup\$ Most MCU's have JTAG, serial, external memory and a few other ways of booting. The best place to check is the (usually long) datasheets. \$\endgroup\$ – Voltage Spike Jul 23 at 17:40
  • \$\begingroup\$ Looking at page 196 of the datasheet suggests that I need to build a basic programming circuit to enable "Monitor Mode" before I can successfully flash it? - nxp.com/docs/en/data-sheet/MC68HC908QB8.pdf \$\endgroup\$ – Joe Mann Jul 23 at 18:03
