I am trying to design an instruction register and controller for an ALU that I designed previously. I made the register with 2 muxes and 2 D flip-flops, and I made the controller with a T flip-flop and a part I programmed in VHDL. Both the BDF and the VHDL file compile successfully; however, when I try to run a simulation with Quartus's University Program VWF, I always get errors that prevent the simulation. I've run a lot of simulations for other projects, and I've never had this issue before. Any help would be appreciated. Here's my VHDL code:
library ieee; use ieee.std_logic_1164.all;
entity Controller is port(
S: in std_logic;
IR: in std_logic_vector (1 downto 0);
IR_LD: out std_logic;
MSA: out std_logic_vector (1 downto 0);
MSB: out std_logic_vector (1 downto 0);
MSC: out std_logic_vector (2 downto 0)
end Controller;
architecture behavior of Controller is
begin
IR_LD <=
(NOT S);
MSC(2) <=
(S AND IR(1));
MSC(1) <=
(S AND IR(1) AND IR(0));
MSC(0) <=
(S AND IR(1));
MSB(1) <=
((NOT S) OR IR(1) OR IR(0));
MSB(0) <=
(S AND (NOT IR(1)) AND (NOT IR(0)));
MSA(1) <=
(S AND IR(1));
MSA(0) <=
((NOT S) OR IR(1) OR (NOT IR(0)));
end behavior;
Here are screenshots of my BDF:
Here's a screenshot of the vwf file:
And here's a screenshot of the part of the Simulation Flow Progress report where the errors occur:
The errors read as follows:
** Error: Waveform.vwf.vht(39): near "In": (vcom-1576) expecting IDENTIFIER.
** Error: Waveform.vwf.vht(41): near "Out": (vcom-1576) expecting IDENTIFIER.
** Error: Waveform.vwf.vht(63): near "In": syntax error
** Error: Waveform.vwf.vht(71): Statement cannot be labeled.
** Error: Waveform.vwf.vht(89): near "t_prcs_": Identifier may not end with >an underline.
** Error: Waveform.vwf.vht(89): near "\In\": (vcom-1576) expecting == or '+' >or '-' or '&'.
** Error: Waveform.vwf.vht(89): near "3:": (vcom-111) No digits found in >mantissa part of based literal.
** Error: Waveform.vwf.vht(89): near "3: ": (vcom-113) Mantissa part of based >integer literal terminates with ' '; should be ':'.
** Error: Waveform.vwf.vht(92): Illegal concurrent statement.
** Error: Waveform.vwf.vht(93): near "In": syntax error
** Error: Waveform.vwf.vht(94): Illegal concurrent statement.
** Error: Waveform.vwf.vht(95): near "In": syntax error
** Error: Waveform.vwf.vht(96): Illegal concurrent statement.
** Error: Waveform.vwf.vht(97): near "PROCESS": (vcom-1576) expecting ';'.
End time: 19:21:31 on Jul 23,2019, Elapsed time: 0:00:00
Errors: 14, Warnings: 0
** Error: c:/intelfpga_lite/18.1/modelsim_ase/win32aloem/vcom failed.
Executing ONERROR command at macro ./LAB6_Part1.do line 4
