Given this circuit, I have to find \$\frac{V_2}{V_1}\$ as well as the magnitude of hysteresis.
I don't need a full solution. Any hints to approach this problem would suffice.
So far, I know the left op-amp is a Schmitt trigger and the right one has unity gain.
Edit update:
Now I know that in case Schmitt trigger outputs 5V Inverting op-amp makes it -5V
applying voltage divider in this case with 5 at one side and -5 at the other.
I get two values either 7.5 or 2.5, 2.5 seems the correct answer but if I take 0.75R as the voltage drop for V+ then it's not correct why?
Is it that the V+ automatically thinks that taking 7.5 as the reference Overshoots the saturation Voltage of the op-amp itself?
update: V2/V1 graph looks like this,
Inference: I tried to apply Voltage divider in the case where negative/positive potential was present instead of ground and I failed terribly.
