Altium (19.0.10) says the following nets contain floating input pins:
CLR
DIN
LATCH
SCLK
But they seem connected (and on grid) to me (see below). Earlier they were directly connected, no luck. I created an empty project, added this schematic and compiled and got the same errors (and a few bonus errors). Also, I don't want to suppress these errors; I want to fix them.
altium schematic
Even if I connect the schematic to its parent schematic (see below), I get the same errors.
parent schematic
Also, I'm getting "Net [] has only one pin..." errors/warnings for these pins (and many others) in my top level schematic. I've checked and everything is on grid (and I think I have my buses/taps named correctly --e.g. SDO1, SDO2... SDO12 go to SDO[12..1]).
Again, I don't want to place directives to silence the errors. Any other comments are welcome (I'm an Altium newb).
  • \$\begingroup\$ are the ports connected to anything else in the schematic ? \$\endgroup\$
    – efox29
    Commented Jul 28, 2019 at 1:34
  • \$\begingroup\$ No. The nets in question are confined to the image I uploaded (I checked with Alt-LMB) \$\endgroup\$
    – Ralph
    Commented Jul 28, 2019 at 1:38
  • \$\begingroup\$ thats probably the problem - not in front of Altium right now to try. Try connecting something (other than a port, an off-sheet connector, or a wire) to it to see if it goes away. \$\endgroup\$
    – efox29
    Commented Jul 28, 2019 at 1:40
  • \$\begingroup\$ altium.com/documentation/18.0/display/ADES/… \$\endgroup\$
    – efox29
    Commented Jul 28, 2019 at 1:42
  • \$\begingroup\$ Building on efox29's comment, Altium takes issue sometimes with unconnected ports or ports that cross several levels of sheets (i.e. sheet within a sheet within a sheet), try connecting the other end of the port to something and see if you still have the same issue. You can set net names to be local or global but Altium wants to see something on the other end of the wire, otherwise Place->Directives->Generic No ERC can be used to suppress the error if you do not intend to connect the nets but would like them named. \$\endgroup\$
    – Sam
    Commented Jul 28, 2019 at 1:43
The issue is the symbol for u_iso7762 has those pins defined as ACTIVE inputs, but nothing connected to those are defined as ACTIVE outputs with exception of power and gnd.
You can fix this by removing the input/output from the component or make sure that the components those nets connect to also have their pins defined as in or output.
You didn't show what, if anything, drives the e.g. CLR1, CLR2, etc. nets.
The warning is simply telling you that no Output type pin is connected to the net; or for the single-pin case, no other connection exists, regardless of pin type.
The underlying system is schematic ERC (Electrical Rule Check). This is somewhat of an anachronism; it was most important back in the days before hardware description languages, where schematic capture was used primarily for data entry, where outputs must connect to inputs following strict rules, like a single output driver per net, etc.
ERC is not so useful these days, for general interconnection of modules where connection is direct (point-to-point), or not even unidirectional, and it's hardly useful at all for analog purposes (where Passive-type pins, like resistors and capacitors, are interspersed between Output-type pins like op-amp outputs, unless one feels it worthwhile to create variants of all such components to propagate Output-ness and Input-ness through said components), but it's still just useful enough on the whole (or not annoying enough to avoid) that it's not worth disabling/removing entirely.
The error level is controlled under Project Settings (Error Reporting, Connection Matrix); most emit warnings by default.
My first guess would be that this has to do with the REPEAT statement. Have you tried reversing the indices?
Anyways, after also having lots of troubles (especially there not being a 0 index) I have stayed away from the REPEAT statement. Instead, I decided to simply place multiple instances of the sheet symbol (not copies of the sheet). This also allows more fine-grained control over which net goes into which instance instead of relying on indices. I highly recommend this approach even if it means you'll need a little more space in the schematic.
