This is the given equivalent circuit for the above parameters (from the problem's solution):
The resistance is R2[(1-s)/s].
However, my textbook shows that the resistance is instead R2/s for the equivalent circuit of an induction motor:
What is the significance in the discrepancy between R2/s and R2[(1-s)/s]?
In your top circuit, R2 is also shown as a seperate component. In the bottom circuit, R2 is combined such that: -
$$R_2 + R_2\cdot\dfrac{1-s}{s} = \dfrac{R_2}{s}$$
R2/s = R2 + R2[(1-s)/s]
The power dissipated in R2/s is the total power developed in the rotor. The power in R2 is dissipated as heat in the rotor. The power in R2[(1-s)/s] is electrical power converted to mechanical power.
Breaking R2/s into two parts more clearly illustrates what happens to the power developed in the rotor.
  • \$\begingroup\$ I think you need to check your algebra. \$\endgroup\$
    Commented Jul 28, 2019 at 15:05
  • \$\begingroup\$ Thank you @Andy aka \$\endgroup\$
    – user80875
    Commented Jul 28, 2019 at 15:12
