I just bought a DC 3 wired voltmeter and it was working perfectly. Here is it image:
I used the yellow wire for measuring the voltages. But for some reason, I desoldered the wires and soldered pin headers. Now it gives unknown reading like 0.XY (eg 0.37) whenever I just connect the positive and negative to battery. It was not happening before.
Can I be helped to troubleshoot what I did wrong? Have I damage the circuit?
Here is the underneath image of the one I soldered:
    \$\begingroup\$ those pins do not appear to be soldered to the PCB \$\endgroup\$
    – jsotola
    Jul 28, 2019 at 18:26
  • \$\begingroup\$ Is the battery voltage too low by any chance? \$\endgroup\$
    – winny
    Jul 28, 2019 at 18:27
  • \$\begingroup\$ @winny I am providing it 5V. \$\endgroup\$
    – Nouman
    Jul 28, 2019 at 18:28
  • \$\begingroup\$ Strange. It’s however my go to thing with incorrect readings on DMM (yours is similar but not a DMM) as low battery voltage often give high readings. \$\endgroup\$
    – winny
    Jul 28, 2019 at 18:29
  • \$\begingroup\$ What are you connecting the 'pin headers' to? \$\endgroup\$ Jul 28, 2019 at 18:32
There's no reason I can think of why you'd get different behavior if you did the desolder/solder job well.
The underneath part you show doesn't show good solder flow around the added header pins. So perhaps there's an intermittent problem due to poor/lack-of soldering?
But otherwise, I don't know of a reason why replacing wires with header pins should change its behavior.
