I'm taking a module at University that involves MPLab. I'm trying to get it setup at home and so far its been a little tricky. I've got my files from University which I've attached below - if there any help in regards to finding out what language toolsuite I need to use, then that would be great. If it helps, when I use the Project Wizard the device that it gives me is: PIC24FJ128GA010
Version: MPLAB IDE v8.87
My current issue with MPLAB
Each time I try build my files that I've attached, all I get is Build Failed. For my debugger I'm using Proteus VSM 7.8. I believe it's a compiler error - I don't believe I've got the correct compiler setup, or even setup a compiler at all.
Test Files: https://www.dropbox.com/s/sekuzv92jsjpaht/testFiles.rar (these work fine on the University computers but when I try build from home it just fails).
I'm sorry if this is a little vague but I'm very new to MPLAB but I'd like to learn more of its features so I'm trying to get it working at home. I apologise in advance if I've not included the correct information and/or missed anything out, if I have, I'll add it as soon as possible. Many thanks.
