I am relatively new to verilog, please help with this issue I am having.
Attached is a snippet of the code I am working on. The issue I am facing is, the regs - del1 and del2 are not correctly passing their values when used inside the "always @ " instruction set.
module pwm(clk,en,duty_cycle, switch, out, out1, out2, out3, pulT, pul1T, pul2T, pul3T, pulB, pul1B, pul2B, pul3B, ENABLE, sel, selo);
input clk;
input en;
input ENABLE;
input switch;
input [7:0]duty_cycle;
output reg out;
output reg out1;
output reg out2;
output reg out3;
output reg pulT;   //
output reg pul1T;  //
output reg pul2T;  //
output reg pul3T;  //
output reg pulB;   //
output reg pul1B;  //
output reg pul2B;  //
output reg pul3B;  //
output reg sel;
output wire selo;
reg seloop;  //Q3
reg seloon;  //Q4
reg selop;   //Q1
reg selon;   //Q2
reg [7:0]counter;
reg [7:0]next_counter;
reg [8:0]ctr12;
reg [8:0]next_ctr12;
reg [8:0]ctr34;
reg [8:0]next_ctr34;
reg shift;
reg del1;
reg del2;
parameter dt = 30;
parameter d11 = 60;
parameter d21 = 80;
parameter d12 = 110;
parameter d22 = 130;
parameter mp = 65;
clk_div2 u1 (.clk(clk), .clk_div2(clk_div2));
assign selo = clk;
always @ *
begin
case(switch)
1:  begin del1 <= d11; del2 <= d21; end
0: begin del1 <= d21; del2 <= d22; end
endcase
end
always @ (posedge clk_div2)
begin
ctr12 = next_ctr12;
ctr34 = next_ctr34;
// --- Set -1 outputs --- //
if (counter >= 255) begin
sel <= ~sel;
end
// ---- S 1 & 2 -------//
if (ctr12 <=(del1-dt)) begin //if (ctr34 <=(shift-dt)) begin
selop = 0;
selon = 1;
end
else if (ctr12 >(del1-dt) && ctr12 <= (del1+dt)) begin //else if (ctr34 >(shift-dt) && ctr34 <= (shift+dt)) begin
selop = 0;
selon = 0;
end
else if (ctr12 >(del1+dt) && ctr12 <= (del1+256-dt)) begin //else if (ctr34 >(shift+dt) && ctr34 <= (shift+256-dt)) begin
selop = 1;
selon = 0;
end
else if (ctr12 >(del1+256-dt) && ctr12 <= (del1+256+dt)) begin  //else if (ctr34 >(shift+256-dt) && ctr34 <= (shift+256+dt)) begin
selop = 0;
selon = 0;
end
else if (ctr12 >(del1+256+dt) && ctr12 <= (512)) begin //else if (ctr34 >(shift+256+dt) && ctr34 <= 512) begin
selop = 0;
selon = 1;
end
else begin
selop = 0;
selon = 0;
end
//----------- S 3 & 4 ------//
if (ctr34 <=(del2-dt)) begin //if (ctr34 <=(shift-dt)) begin
seloop = 1;
seloon = 0;
end
else if (ctr34 >(del2-dt) && ctr34 <= (del2+dt)) begin //else if (ctr34 >(shift-dt) && ctr34 <= (shift+dt)) begin
seloop = 0;
seloon = 0;
end
else if (ctr34 >(del2+dt) && ctr34 <= (del2+256-dt)) begin //else if (ctr34 >(shift+dt) && ctr34 <= (shift+256-dt)) begin
seloop = 0;
seloon = 1;
end
else if (ctr34 >(del2+256-dt) && ctr34 <= (del2+256+dt)) begin  //else if (ctr34 >(shift+256-dt) && ctr34 <= (shift+256+dt)) begin
seloop = 0;
seloon = 0;
end
else if (ctr34 >(del2+256+dt) && ctr34 <= (512)) begin //else if (ctr34 >(shift+256+dt) && ctr34 <= 512) begin
seloop = 1;
seloon = 0;
end
else begin
seloop = 0;
seloon = 0;
end
//selo = clk;
end
next_ctr12 = ctr12+1;
next_ctr34 = ctr34+1;
endmodule
module clk_div2(clk,clk_div2);
input clk;
output clk_div2;
reg clk_div2 = 1;
reg [2:0]counter;
reg [2:0]next_counter;
always @ (posedge clk)
begin
counter = counter +1;
if (counter>=2) begin
clk_div2 <= ~clk_div2;
counter = 0;
end
end
endmodule
My expectation was that if the "switch" toggles, del1 and del2 will get different values and the instruction set under "always @" will change accordingly. But its not working at all. I did some research on this and my guess is the regs dela1 and del2 are not resetting and hence it is in dont care condition. But I guess I dont know how to reset it, can you please help? What else might be the reason? I also tried setting del1 and del2 as wire, that approach doesnot work as well. Is something wrong with the way "always@" is set up?
    \$\begingroup\$ Start with fixing your assignments, they are just the wrong way around: In the always @( * ) you should use blocking assignments =. In the @ (posedge clk_div2) you should use non blocking: <=. Then get a waveform display running and check what is happening. Oh and you should avoid using "derived clocks" (clk_div2). Use one general clock with an enable. \$\endgroup\$ – Oldfart Jul 31 at 18:37
  • \$\begingroup\$ Your code is kind of a mess. You are using non-blocking assignments for combinational logic, and mixing blocking and non-blocking assignments in a clocked block. Have you defined a clk_div2 module for U1? Why are you using the same identifier (clk_div2) for different purposes? \$\endgroup\$ – Elliot Alderson Jul 31 at 18:39
  • \$\begingroup\$ Please post a minimum verifiable example they demonstrates the issue. Please also properly indent and format the code \$\endgroup\$ – Tom Carpenter Jul 31 at 18:39
  • \$\begingroup\$ Sorry forgot the u1, added. I will fix the blocking and nonblocking issues tonight and try it out. Elliot, I see what you mean, that might be an error on my part, I will try to fix that too. But does that explain del1 and del2 being dont care? \$\endgroup\$ – Am1T Jul 31 at 18:46
  • \$\begingroup\$ del1 and del1 are defined as reg which is only 1-bit. Try defining them as reg [7:0]. \$\endgroup\$ – Greg Jul 31 at 19:00
Also fold in Oldfart's and Elliot's suggestion of fixing blocking (=) / non-blocking (<=) assignments. Combinational logic (eg: always @*) should use blocking (=). Sequentail logic (eg: always @(posesge clk)) should use non-blocking (<=)
