I have hit a point in my LED project where I am about to introduce a second power supply (5V 60A Source - Amazon Link Here) and I would like to ensure a common ground. Think of the project as one continuous LED strip with power introduced at intervals to ensure the lights are supplies with ample power.
So far, one supply has 4 terminals which can supply power to the Microcontroller and 3 different points along the LED strip. Adding a second supply brings up the question of how to share the ground.
My thought process is this:
- The ground must be shared throughout the project/full LED strip like what we see in the image above.
- With 2 power supply sources which are pulling from 2 seperate plugs introduces 2 different grounds, going against #1
- Either:
A) The two power supplies should pull from the same source, like through a Distribution box (lunchbox or distro box for all us film industry folks Example of a Distro box here). So even though the 2 supplies are pulling from different 2 plugs, the source of those 2 plugs is the same line.
-OR-
B) The grounds are connected after the fact and since they are connected, it just becomes one connected ground source.
The question:
Are either of these approaches correct?
