In smartening up my doorbell I've been playing with my illuminated pushbutton and have fallen into a bit of a rabbit hole. The doorbell normally:
My understanding of this is that when the switch is open the bulb lights up and there is not enough current to fire the chime. When it is closed the short circuit then provides enough current to the chime to fire its coil. I used my multimeter to discover that the pushbutton lamp has a resistance of 60ohm, and the chime 6ohm. The AC source is 8VAC.
My enterprising idea was to replace the chime/coil with an optocoupler which would trigger something downstream (an ESP32 in my case). First I tried to get it all working with an LED, so to end up with a lit bell that lights the LED when pressed.
Here the lamp is always off, and the LED is always lit. Which is expected - the current is way too low for the lamp due to the now larger resistance. But reducing this resistor will probably burn out the LED. So:
  1. Is what I want to do even possible? That is, to ordinarily have a high enough current pass through the button in order to illuminate the lamp but not the LED, but when pressed, have the short circuit light up the led instead? I guess what I really want is a low resistance optocoupler that can handle a high current. Does that exist, or is it possible to build one from basic components?
  2. If not, what's the mental model here that would show this isn't possible? Is it that the LED requires much less current than the lamp so shortcircuiting the lamp doesn't make sense since by definition the current would increase?
To be clear I'm more interested in learning here than getting a working circuit - aside from solutions using mechanical relays and current sensors I'd probably choose to just use a normal (ie not illuminated) doorbell instead.
  • \$\begingroup\$ YOu need a current rectifier, reverse protection and current limiting. What are your specs? Without all the specs for supply and load, no chance. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 1 at 17:15
    \$\begingroup\$ "... the pushbutton lamp has a resistance of 60ohm ..." - I assume it's an incandescent bulb? Is 60 ohm the cold resistance, or the hot resistance? \$\endgroup\$ – marcelm Aug 1 at 17:22
  • \$\begingroup\$ @marcelm, cold resistance. \$\endgroup\$ – Spammy Aug 1 at 18:11
  • \$\begingroup\$ @sunny I'm not sure which further specs to give? The led has VF of 2v (the optocoupler less). Assume the optocoupler needs 10ma? \$\endgroup\$ – Spammy Aug 1 at 18:13
  • \$\begingroup\$ @Spammy 8V ? Transformer , VA rating . bulb W and Voltage rating ??? You cant drive a 230V bulb with 8V \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 1 at 18:31
I would try something like this. You want the new circuit to have roughly the same characteristics as the chime. I don't know enough about the details to give exact values.
The value of R1 needs to be small enough to light the lamp, but not too small or the transformer will be stressed when the button is pushed. See if you can see the rating of the doorbell transformer, they are often mounted directly on the main breaker box. R1 should be sized (wattage) so it doesn't burn up if the switch is held closed.
D3, or several diodes in series, or a zener, is optional, if needed to raise the threshold so the opto isn't on when the switch is open. I am assuming that 60 ohms is the cold resistance of the lamp. The hot resistance should be high enough to keep the opto off.
  • \$\begingroup\$ The transformer is 2A, with various terminals to supply 4, 8 or 12v. The lamp only lights up with 8v, I've not tried 12v (I assume I don't need to). I'm now trying to understand the circuit, thanks! \$\endgroup\$ – Spammy Aug 1 at 18:15
  • \$\begingroup\$ So if I need to = maximum 10ohm for the lamp to light, that means a current of 8/10 = 0.8A. Does that mean I'd need a 0.8*8 = 6.4w resistor? Also the optoisolators I have lying around are pc817s \$\endgroup\$ – Spammy Aug 1 at 21:05
  • \$\begingroup\$ Yes, there will be a lot of power dissipated in the resistor if the switch is held down. So, you want to use the largest value resistor that will light the bulb satisfactorily. I am guessing that it will be somewhere around 30 ohms. The optocoupler type isn't critical. \$\endgroup\$ – Mattman944 Aug 1 at 21:19
  • \$\begingroup\$ I have built this circuit (using the chime for R1 as I don't have an equivalent high power resistor available) and without D3 and am happy to report that it works as expected. However (possibly also expected) the signal coming out of the optocoupler appears to be cycling with the frequency of the AC supply. I presume I am to rectify this somehow? Should that be on the bell or supply side of the opto? \$\endgroup\$ – Spammy Aug 2 at 15:49
  • \$\begingroup\$ If the ultimate goal is to connect to a microcontroller, the microcontroller can handle the pulses in software. \$\endgroup\$ – Mattman944 Aug 2 at 16:05
