I have a arduino running with bitlash running on it connected to a shiftbrite.
I can use a terminal program to send it commands such as rgb(1023,0,1023) and it will work but when I do it with python it doesn't.
Here is my python code. I don't know why it doesn't work. I can even print the string on an LCD connected to it and it comes out correctly
#Python Menu
#File: PythonMenu.py
#Basic menu system for use with Arduino and Shiftbrites
#over a wireless xbee link
import os #For clear
import time #For delay
import serial #For serial comms to the device
def printMenu():
    """Prints the menu ready with all options"""
    print "/--------------------------------------------\\"
    print "|      |  | |  | /--- |  |  __  ---|         |"
    print "|      |--| |  | |  - |--| |__ |___          |"
    print "|      |  | |__| |__| |  | |__  ___|         |"
    print "|--------------------------------------------|"
    print "| Please select from the following options   |"
    print "|                                            |"
    print "| (1) White                                  |"
    print "| (2) Red                                    |"
    print "| (3) Green                                  |"
    print "| (4) Blue                                   |"
    print "| (5) Fade                                   |"
    print "| (6) Off                                    |"
    print "| (0) Exit                                   |"
    print "\\--------------------------------------------/"
def clear():
    """Clears the console screen"""
    os.system('clear')
def sendColour( r, g, b ):
    """Sends a RGB value to the shiftbrite"""
    #build up string
    tmpData = "rgb("
    tmpData += str(r)
    tmpData += ","
    tmpData += str(g)
    tmpData += ","
    tmpData += str(b)
    tmpData += ")"
    ser.write(tmpData)
    print(tmpData)
    return
#Setup serial
ser = serial.Serial('/dev/tty.usbserial-A600dJm8',9600)
#Start main code LOOP
while True:
    clear()
    printMenu()
    userInput = raw_input('Selection:')
    if userInput == '1':
        sendColour(1023,1023,1023)
    elif userInput == '2':
        sendColour(1023,0,0)
    elif userInput == '3':
        sendColour(0,1023,0)
    elif userInput == '4':
        sendColour(0,0,1023)
    elif userInput == '5':
        sendColour(0,0,0) #To be implemented
    elif userInput == '6':
        sendColour(0,0,0)
    elif userInput == '0':
        print "Quitting"
        ser.close()
        exit()
    time.sleep(2)
Anyone got any ideas?
  • \$\begingroup\$ perhaps you need to call some kind of flush method on the ser object? \$\endgroup\$ – vicatcu Oct 21 '12 at 4:54
I think you are forgetting a line-feeds / carriage-return character to finish off the command. If you wrote a command in the terminal and hit enter they would be sent.
Change code to:
    #build up string
    tmpData = "rgb("
    tmpData += str(r)
    tmpData += ","
    tmpData += str(g)
    tmpData += ","
    tmpData += str(b)
    tmpData += ")\n"
    ser.write(tmpData)
    print(tmpData)
    return
Note the \n.
The bit lash-cmdline.c file has this in it:
void doCharacter(char c) {
if ((c == '\r') || (c == '\n') || (c == '`')) {
    speol();
    *lbufptr = 0;
    doCommand(lbuf);
    initlbuf();
(rest of function not included)
This suggests a '\r', '\n' or a '`' character can be used to terminate the command.
| improve this answer | |
  • \$\begingroup\$ Arrrah something so simple works perfectly now \$\endgroup\$ – Ashley Hughes Oct 21 '12 at 5:18
  • \$\begingroup\$ Oh man I know the feeling! Glad it works now. \$\endgroup\$ – geometrikal Oct 21 '12 at 5:24
  • \$\begingroup\$ Thanks heaps it is now fully working from my phone controlling lights over an xBee network \$\endgroup\$ – Ashley Hughes Oct 21 '12 at 8:03
  • \$\begingroup\$ Just curious, how are you interfacing the phone to the xBee network? \$\endgroup\$ – geometrikal Oct 21 '12 at 8:46
  • \$\begingroup\$ Oh its a bit crazy. but here is goes Phone -> Internet -> Flask(Python server on computer) -> Flask server sends serial to my xbee -> xbee to arduino \$\endgroup\$ – Ashley Hughes Oct 21 '12 at 10:01
