A few years ago I used the Library of Parameterized Modules from Altera (now Intel). I am now using Xilinx/Vivado, and I can't seem to find any equivalent.
For example, I used to instantiate counters left, right, and center. I find it hard to believe that Vivado doesn't have this facility... but I can't find it!
Am I missing something here?
  • \$\begingroup\$ I have written a lot of HDL code and never wanted to instance a counter. I just write three or four line of code and often the counter disappears within the rest of the sequential logic. "Am I missing something here?" Maybe HDL has moved on a bit. I would say that in HDL it is just not worth the hassle to instance a counter. It really gets awful if you need to set, clear, increment etc. depending on a state variable. But that is just my opinion... \$\endgroup\$
    – Oldfart
    Commented Aug 5, 2019 at 16:48
    \$\begingroup\$ This right here is exactly why I try to avoid as much vendor specific stuff as possible... It doesn't necessarily save much time in the short term, but it can cause lots of headaches later \$\endgroup\$ Commented Aug 6, 2019 at 17:42
With Vivado you can do this one of four ways:
  • Define the counter with HDL (uses fabric and LUTs)
  • Instance a DSP48 with HDL
  • Use block design Binary Counter, instance as 'fabric'
  • Use block design Binary Counter, instance as 'DSP48'
You can also define your own parameterized RTL blocks if you need something more exotic than that.
