How can I charge a LiPo battery (4 cells) without the "classical Lipo Balance Charger".
Also, is it possible to monitor the battery level from, let's say a Raspberry Pi?(Using the 4 pins that are used only when charging).
If not, what kind of accumulator should I use for this?
Thank you!
  • \$\begingroup\$ Considering the danger of charging lipo batteries, you should use a charging IC, and as for monitoring, either by voltage with a resistor divider, or with a complex dedicated battery monitor depending on accuracy needs. \$\endgroup\$ – MadHatter Aug 6 at 12:08
