The official JEDEC standard to number pins on a TO-92 package is the following:
But in many datasheets from Texas Instruments, this order seem reversed. For example, this is a screenshot from the datasheet for the LM185 :
Link to the full datasheet : http://www.ti.com/lit/ds/symlink/lm185-1.2-n.pdf (page 1)
Texas Instruments's official TO-92 documentation doesn't help since there is an ambiguity as if the drawing is from the top or the bottom : http://www.ti.com/lit/ml/msot002d/msot002d.pdf
In all the datasheets where the pinout is reversed, they used a view from the top or the bottom. In some datasheets the pinout is correct, but they used an isometric view which eliminate all ambiguity. This could be the source of the confusion, but I just don't see how I could misinterpret "Bottom view" or "Top view" for a TO-92 package.
Is Texas Instruments wrong or I don't understand what a bottom view is?
To prove that this is not an isolated mistake in a single datasheet, here are few links to some Texas Instruments datasheets where this happen :
http://www.ti.com/lit/ds/symlink/tl431.pdf (page 4)
