I'm trying to reverse engineer a pcb and I'm stuck on this circuit. I believe the capacitors maybe for debounce. The switch is a reed switch. Can anyone shed any light on it?
Circuit diagram
  • \$\begingroup\$ is the micro pin configured as an input within a passive pullup enabled? \$\endgroup\$ – vicatcu Aug 11 at 1:09
  • \$\begingroup\$ Yes I think it is. \$\endgroup\$ – Samuel Taylor Aug 11 at 2:44
You are correct it is a low pass filter for debouncing the reed switch. Reed switches dont just bounce they can vibrate for some time due to the physical configuration of the contact arms.
  • \$\begingroup\$ This is just to block RF noise. True debounce is done internally as simple digital filters. \$\endgroup\$ – Sparky256 Aug 11 at 8:09
  • \$\begingroup\$ I understand the use of the caps but why the resistors? Sorry if this seem a dumb question just trying to learn. :) \$\endgroup\$ – Samuel Taylor Aug 11 at 11:49
    \$\begingroup\$ This is a RC (resistor capacitor) filter the time constant is R x C.You need resistance to provide some delay so the capacitor charges less rapidly. \$\endgroup\$ – RoyC Aug 11 at 14:11
