I am planning to interface a STM32H753XI to a 1400x480 display. Here is the reference manual. Now, the maximum resolution given for the STM is 1024x728. I understand that this is the maximum frequency the device can actually output.
Now my desired horizontal resolution exceeds the controllers 1024 pixels. I checked with the registers and they support 11 bit values (so everything up to 2047). Has anyone tried to interface a display with a larger horizontal resolution to an STM? Are the horizontal and vertical pixels a hard limit or is the combined pixel clock frequency the actual limit?
  • \$\begingroup\$ maximum resolution according to what document?? This is more likely a function of the drivers you've found and the choices made for what peripheral will drive the display than limitations of the microcontroller \$\endgroup\$ – Scott Seidman Aug 12 at 18:33
  • \$\begingroup\$ @ScottSeidman according to the website I linked (XGA resolution) and the LTCD peripheral in the STM32. Also, Stm32cubeIde limits the value for the horizontal resolution to 1024 but you could override it. \$\endgroup\$ – Tom L. Aug 12 at 18:40
The question was answered in the STM32 Q&A forums with a link to this document.
Basically the limit is the maximum resolution according to the registers (4096x2048) but what is more important is the bandwidth to the framebuffer memory (typically in a connected SDRAM). So it seems that the resolution should be possible but we're already quite near the limit.
