For the circuit above (for steady state I guess, if it is important) impedance of the capacitor is calculated using $$Z_c=\frac{1}{j\cdot\omega\cdot C}$$ So,$$Z_c =-j2000\;\Omega$$My question is why unit of \$Z_c\$ is not\$\;\frac{\Omega}{rad}\$ because \$\omega\$ has unit of \$\frac{rad}{second}\$ and C has unit of Farad which is equivalent \$\frac{second}{\Omega}\$ and I assumed \$j\$ is dimensionless.
I will be glad if you help me. Also I am not sure whether or not my question is reasonable.
Radians are a ratio (arc length over radius), so a dimensionless quantity.
The units of \$\omega\$ are 1/s. That's also true of the Laplace transform's complex frequency variable s.
  • \$\begingroup\$ technically though the radian is a unit of measure, it is a dimensionless quantity. \$\endgroup\$
    – vicatcu
    Commented Aug 12, 2019 at 21:48
    \$\begingroup\$ @vicatcu Edited. \$\endgroup\$ Commented Aug 12, 2019 at 21:50
If you are familiar with RC circuits, you know that RC has dimensions of time. So C has units of sec/ohm and 1/C has units of ohm/sec. When you multiply this by 1/frequency, you get (ohm/sec) * sec = ohms
