I've seen different types of min/max voltages in this datasheet and not sure whether I've understood them correctly, so I want to double-check it here.
As shown below, there two types of min/max voltages:
  1. Voltage available zone: The voltage provided should fall into this zone, like Reset drain voltage with min=11/max=13, which means the voltage provided to this pin should between 11v and 12v;
  2. Voltage threshold zone: It's the uncertain area of the threshold, so voltage provided should be out of this zone, like the high level of Vertical shift clock voltage with min=4/max=8, which means the high level threshold may between 4v and 8v, so the high level of the generated clock should be over 8v.
Do I understand these parameters correctly?
  • \$\begingroup\$ Rather than just give a datasheet link, please edit your question to state the device manf., part number and description for readers. \$\endgroup\$
    – TonyM
    Commented Aug 13, 2019 at 4:10
  • \$\begingroup\$ Why are you assuming point 2? Why should it be higher than 8V? \$\endgroup\$
    – User323693
    Commented Aug 13, 2019 at 4:49
