This is what I understand about the circuit:
  1. It's not a window comparator exactly as the outputs are not connected together and the inverting inputs are actually connected together. They look like two Schmitt triggers.
  2. Resistors R15 and R16 are pull up resistors as the comparators outputs are open collector.
  3. R8, R9, and R10 form a resistor divider network to set the voltage references. According to my calculations, I get 10.2V for V1 and 6.46V for V2.
Correct me if I said something wrong.
What I don't understand:
  1. What's the purpose of the diodes in the positive feedback?
EDIT:
R11 = R12 = 200k
R13 = 332k
R14 = 237k
I found this question that gave me a better insight on why the diode on the feedback path:
Diode in positive feedback?
  • \$\begingroup\$ We need the values of R11 to R14 to calculate the thresholds. The saturation voltage of the output transistors would also be nice. What is the comparator? \$\endgroup\$
    – devnull
    Commented Aug 13, 2019 at 17:35
  • \$\begingroup\$ I added the values R11 to R14. \$\endgroup\$
    – user115094
    Commented Aug 13, 2019 at 18:15
Since there is hysteresis, we must analyze the behavior in a specific direction. If you provide the values and specify the comparator, I can update the description (if needed).
  • Input = 0 V
Both comparators will output the the highest possible voltage (pull-ups). The feedbacks will be open due to the diodes, and the thresholds will depend only on R8, R9 and R10, if the input current can be disregarded.
  • Input > V1
The comparator below will saturate its output, its feedback diode will conduct and both thresholds will be reduced.
  • Input > V2 (reduced)
The comparator above will saturate its output, its feedback diode will conduct and the thresholds will be reduced again.
The feedback networks will only be conducting when the comparators are saturated (low voltage output). When both Out1 and Out2 are high, the thresholds will depend only on R8, R9 and R10.
