Below is a basic not Gate using nandgate.
Not Sure why output is X, when I change it to Output properties to three state no, I can't modify circuit.
Some times, these issues go away when I restart logisim.
some more weird issues...
My Alu output shows E
I tracked down that to below highlighted Mux gate
When I drill down to that gate it shows x on output enter image description here
When I tried to modify that, it gives this popup
when I click ok and try to change input, x in output will be gone.
All my subcircuits are fine individuallly, when combining them to make ALU, these kind of weird issues popup, when drilling down, we will see results like above.
Faced same issue with adder, but restarting logisim fixed the issue.
Any ideas or pointers ...?
Make sure that simulation is enabled (in the Simulation menu). If simulation is disabled, the states of signals in your circuit will not be updated.
  • \$\begingroup\$ Actually, the simulation is enabled and even when trying to change input to 1/0 doesnt change output \$\endgroup\$ – TheGameiswar Aug 15 '19 at 2:49
  • \$\begingroup\$ when i closed this and reopened and it works.Getting strange errors like this \$\endgroup\$ – TheGameiswar Aug 15 '19 at 2:49
  • \$\begingroup\$ Weird! That's the only way I was able to reproduce the result shown in your screenshot -- if simulation is enabled, a floating (blue) input to an AND gate would normally result in an undefined (red) output, not another floating output. \$\endgroup\$ – duskwuff -inactive- Aug 15 '19 at 2:52
  • \$\begingroup\$ Added some more data to question.Thanks for your time on this \$\endgroup\$ – TheGameiswar Aug 15 '19 at 3:00
