Broken Connector Image
This connector got damaged while repairing a device, and I've been unable to identify it to replace it.
The connector is SMD mounted with the circuit board underneath based on the image above. It is 1mm pitch and has (had) 5 pins. The cable connects/disconnects by lifting vertically away from the PCB.
Socket dimensions: 7.8mm x 4.5mm x 1.4mm, 1mm pitch, pins are 1mm long 0.2mm thick.
Plug dimensions; 7.1mm x 3.7mm x 1.2mm, the cable ends appear to be crimped.
Better image: Higher res connector image
Cable end (the empty connection was always empty, the connector has space for five connections, only four are used): Cable Image
  • \$\begingroup\$ Need more focus. \$\endgroup\$
    – DKNguyen
    Aug 15, 2019 at 3:57
  • \$\begingroup\$ I've added the new images \$\endgroup\$ Aug 15, 2019 at 4:25
    \$\begingroup\$ Need pin pitch and connector dimensions, measured with calipers. \$\endgroup\$
    – Voltage Spike
    Aug 15, 2019 at 5:20
  • \$\begingroup\$ I've added the dimensions, my calipers are cheap so they are all +/- 0.1mm \$\endgroup\$ Aug 15, 2019 at 17:36
Looks like a Molex Pico EZMATE header WM4461CT-ND and the plug WM4462-ND. Those are Digi-Key numbers as I found them there but Molex parts are available all over. Pitch on these two parts is 1.20MM
