I'm trying to use the ROM bootloader on the SAMG55 as described in AT09002. The application note describes using a tool 'hex2fw.py'. Where can I get that and the config files it uses?
I found this thread - https://community.atmel.com/forum/entering-bootloader-atmel-samg55-xplained-pro - which has a modified version of the script, but no config files that it needs.
After some research, I tracked down a copy of the zip file (20831 bytes) for Atmel Application Note AT09002 which was stored in the Wayback Machine (archive.org) on 1st August 2017:
Atmel-42305-SAM-I2C-SPI-Bootloader_ApplicationNote_AT09002.zip
It contains the Python tool hex2fy.py and config files which you mentioned.
That's the latest version which I could find archived there.
