For C-V curve below for 3 different materials, (Si, InAs, InSb). What material will be corresponding to curve A/B/C?
My understanding is that C is inversely proportional to the dielectric constant in the inversion region. As a result, Si has the smallest dielectric constant and therefore matches with C. InAs = B InSb = Center image description here
Is my understanding correct? Thank you for your help!
Yes. You are correct, if they all have the same cros sectional area and same doping concentration in the semiconductor.
For a MOS capacitor, the capacitance value in inversion region is given by the the series combination of insulator capacitance (\$C_{ox}\$) and the semiconductor capacitance in inversion (\$C_{s}\$). Since all the three capacitors have same capacitance in the accumulation region, \$C_{ox}\$ values are same. \$C_s\$ depends on dielectric constant of the semiconductor (\$\epsilon_s\$) and doping in the material. So if the doping is can be assumed to be same, then MOS capacitor with least \$C_s\$ will have lowest capacitance.
  • \$\begingroup\$ Thank you for your help! I found the equation Cs = (W_d / ϵ ) ^-1, if ϵ decrease then Cs decrease. this matches what you suggested! \$\endgroup\$
    – tinyhulk
    Aug 16, 2019 at 17:30
  • \$\begingroup\$ @tinyhulk note that \$W_d\$ has a \$\sqrt{\epsilon}\$ term inside. \$\endgroup\$
    – nidhin
    Aug 16, 2019 at 18:26
