I'm designing a product that provides mono audio output via a 1/4" SN49B12B board-mounted socket.
This socket is actually a stereo socket, but I'm wondering if simply wiring the ring and sleeve pins together to ground will effectively make it a mono socket?
Are there any issues with this approach from a product design / durability / robustness perspective? One concern I had was that when plugging, the ring will connect the cable to ground earlier than if there was no ring present - would that create any extra plugging noise or anything like that?
The user will, of course, be using mono TS plugs.
Whether the jack plug gets shorted or not depends on the geometry of the insulation on the plug and the width of the contacts on the socket. Assume the worst - whatever that may be in your design.
You are free to wire the socket any way you desire.
a) This will work with a mono or stereo jack wired tip and sleeve. A stereo plug will have the ring floating and may cause hum in that channel (usually the right).
b) Will work similarly and has the advantage that if a stereo lead is plugged in that the channel will be grounded rather than left floating and producing a hum.
c) This won't work if a stereo lead is plugged in as there is no ground connection.
It's your choice.
