Apologies in advance if my question seems too basic. I don't really know where to go from here.
I understand that power can be calculated as P = IV or P = V^2/R or P = I^2 x R. I think I'm not conceptually understanding how to actually use these formulas together to calculate power dissipation in a component.
For instance, I have this filter here. Its datasheet has a bunch of useful information, in particular rated voltage and rated current, 50Vdc and 15A respectively. I really don't believe I have the correct value for power dissipation if I just multiply the two values and get 750W. That seems far too much to be believable.
If I want to calculate how much power this filter dissipates, where can I find the correct values to calculate power dissipation in this component?
This microwave DC filter has specs;
Large rated current (15A) and Low Rdc (0.8m ohm-typ.)
So \$Pd=I^2R= 15^2* 0.0008 \Omega=0.18W\$
The voltage is for the magnet wire insulation breakdown rating (when scored)
