What is the control theory of PLCs (programmable logic controller)?
PLCs fall in category of linear control or non linear control?
closed as too broad by RoyC, JYelton, Scott Seidman, Oleg Mazurov, Simon B Aug 21 at 10:09
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Far too broad a question. \$\endgroup\$ – Chu Aug 20 at 13:36
  • \$\begingroup\$ "PLC" is just another name for "digital computer", so what do you think? \$\endgroup\$ – Dave Tweed Aug 20 at 13:36
  • \$\begingroup\$ They're programmable so you can use whatever theory you want. \$\endgroup\$ – Transistor Aug 20 at 13:58
A programmable logic controller does what you tell it to. So you can make it implement a linear control rule, or you can make it implement a non-linear control rule.
By itself, a PLC isn't described by one control theory or another.
