This is my first time incorporating fuses in my project. I am trying to source for some DIN rail mount fuse holders and the accompanying cartridge fuses.
After much searching, I have found the fuse I am looking for with a current specification of 500mA. This fuse also has size 32mm x 6mm.
However I can't seem to find a fuse holder with the physical specifications. All I come across is fuse holders with size specifications of 38mm x 10mm.
Will it be possible to use a 32x6 fuse with a 38x10 holder?
  • \$\begingroup\$ They are available. Maybe you need to look harder. \$\endgroup\$
    – Steve G
    Aug 20, 2019 at 15:41
  • \$\begingroup\$ @SteveG I am bit restricted to the shop to purchase from (Aliexpress). Thanks anyway \$\endgroup\$
    – Cerezo
    Aug 20, 2019 at 15:51
No. Even if the fuse seems to fit, it should not be used with a holder that is not specifically designed for the fuse. Fuse performance specifications and independent testing laboratory listings are dependent on use with a fuse holder that is designed for that fuse.
    \$\begingroup\$ Thanks. Needed some one to talk me out of this idea. No cutting corners!! \$\endgroup\$
    – Cerezo
    Aug 20, 2019 at 15:53
32 × 6 mm is the old 1.25" x 1/4" fuse style. There are plenty of DIN holders for these. Your search term is din rail 32 x 6.35 fuse terminal.
