In datasheet they have provided two parameters named Quiescent Current and Operating current in which I am measuring quiescent current i.e, ground current flowing from the device VDD to GND , when device inputs (HI,LI) are grounded (test conditions as mentioned in datasheet.
Electrical Characteristics Table
I am measuring Quiescent current at 1 (VSS) for now from below figure, Or should I consider current at 2 (RT1 and RT2) so that it comes to Quiescent current= Current at 1 + Current at 2 ?
(RT bias voltage is 3V which is given internally)
Test Setup
Where should i measure operating current providing f=500KHz input?
This table gives operating current for 25 degree as 1.5mA
When I relate this to below plot which is w.r.t to temperature the operating current contradicts the table value.
Operating current vs temperature
Can anyone shed some light on these parameters measurements
Carefully look at the subscripts of the parameters (underlined in red):
The current \$ I_{DD}\$ is the current that enters the \$ V_{DD}\$ pin and is therefore called "\$ V_{DD}\$ Quiescent current". So, you should measure this current at the \$ V_{DD}\$ pin.
Same as above, at the \$ V_{DD}\$ pin
Note that the table specifies a typical value. I would also expect this typical value in Figure 2, but probably they used a different measurement setup, yielding a different operating current than the typical value. (Note the same applies to \$I_{HBO}\$.)
It is not uncommon to find such a (seemingly) "inconsistency" in datasheets.
  • \$\begingroup\$ Here is what I understood Quiescent Current and Operating Current is measured at VDD. But, how Operating Current calculated is it average current at VDD? \$\endgroup\$ – Pai Aug 22 '19 at 7:01
