I have been trying to find some passive thermal cutoff switches for a project, but it seems that all of them are for 65 degrees C and up. Is there another name for lower temperature TCOs?
Any help in finding these would be very much appreciated.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have been trying to find some passive thermal cutoff switches for a project, but it seems that all of them are for 65 degrees C and up. Is there another name for lower temperature TCOs?
Yes, thermal normally-open and normally-closed switches do exist for temperatures below 50 Centigrade.
For instance, see the catalog of Thermtrol Corporation, which has several options.
Searching for Thermal Switch on eBay yields this result - a Normally Closed thermal cutoff switch for 45 Centigrade, rated for 250 V / 10 A.
A little further digging might yield better options or prices.
Since TCO defines the protection for electronic equipment and I would think 45'C and up could be available in this catagory, it may be that you need to look at Thermostats or thermo-coupled pressure switches or electronic switches using thermistors or solid state thermal sensors etc etc.
More details on your application could help define the unstated specs. Voltage, current, cycle lifetime, environmental rating, sealed, air/liquid, chemical compatibility etc.
If you are looking for say a 40'C inline TCO , you you need to ride on some existing demand or have purchasing leverage to ask disti's or OEM's like Cantherm, Honeywell for a custom part for say 100K pc's a yr at 10 cents. (ballpark)
