I have made a circuit with ESP8266 which triggers a relay. Actually, I want to bypass a button which is on a 3rd electronic device, which is a closed box with a very complex circuit.
I have soldered out the connections of the switch from that device. By using relay I can short that, but a relay is bit bulky,
Is there any other way to achieve this? (The other device is a DC operated device)
