I am trying to send my data to HTTP server using GET method. When i am sending some hardcoded data manually it is getting stored in database successfully.
SIM900.println("AT+HTTPPARA=\"URL\",\"xxx.xxx.xxx.xxx:xxxx/xxxxxxxxx/api/iot/v1/save-data/10/20/\"");
This is working fine and my data is getting stored successfully.
But when i am trying to send real time data i am unable to send it successfully. Let's say
float h = DHT.humidity;
float t = DHT.temperature;
SIM900.println("AT+HTTPPARA=\"URL\",\"xxx.xxx.xxx.xxx:xxxx/xxxxxxxxx/api/iot/v1/save-data/t/h/\"");
It is storing the value as t and h instead of their real values. I tried some different methods also.
SIM900.println("AT+HTTPPARA=\"URL\",\"xxx.xxx.xxx.xxx:xxxx/xxxxxxxxx/api/iot/v1/save-data/tempData=");
SIM900.print(t);
SIM900.print("&humdData=");
SIM900.print(h);
SIM900.print("\"\r\n");
But i am getting error.
Can anyone please help me and tell me how should i send my data to make it getting saved successfully. Thanks in advance.
When you split the print into several statements, the first one should not be a println, it should be just a print. If you want, the last print statement could be
SIM900.println("\"");
In general, when trying to print a single line with embedded data you will use print() several times but only use println() once, at the end.
