I've created a PCB design for the first time ever, but I would like to know if I've made any mistakes that will result in a broken board or short circuits in the near future. I've encountered people on numerous questions that would like to help in making sure that a PCB is correctly designed and that a "person in this job situation" would love to check it out.
PCB (blue is bottom, red is top)
I would really appreciate any feedback I can get :)
EDIT: Added some more sensors and holes so I can solder anything to the NodeMCU pins later on.
Same improved PCB but with an indication of where each component will reside (note: The board at the left will be at the bottom same for the three resistors at the top and the buzzer at the right bottom)
