How much current is flowing here? enter image description here
The left most position is 0 for currents, the right most if the range value,
So for the 500mA range you would be looking at the lower black range and times any reading by 10,
So in this case, you would be reading 120mA
Or a little bit more accurate:
upper black scale shows 60
60mA x 2 = 120 mA
    \$\begingroup\$ Would have be better if the OP aligned the camera so that the photograph of the needle is coincident with the reflected image of the needle. \$\endgroup\$ – D Duck Aug 26 at 12:17
  • \$\begingroup\$ Yes off course!!! \$\endgroup\$ – Mike Aug 26 at 12:32
