I have a microSD card reader which needs \$5\,\mathrm{V}\$ to operate.
I am interfacing it with STM32 MCU operating at \$3.3\,\mathrm{V}\$.
Will it operate normally when I provide only \$3.3\,\mathrm{V}\$?
Presently, I do not have \$5\,\mathrm{V}\$ to supply to the card reader but only \$3.3\,\mathrm{V}\$.
Datasheet link is here. enter image description here
    \$\begingroup\$ What does the datasheet say? \$\endgroup\$ – Hearth Aug 27 '19 at 20:48
    \$\begingroup\$ microSD card adapters are typically passive devices which operate at whatever voltage is supplied by whatever system you plug them into. \$\endgroup\$ – brhans Aug 27 '19 at 20:49
    \$\begingroup\$ please be clear in your question. or, you can draw a setup(post an image) to explain it better \$\endgroup\$ – User323693 Aug 27 '19 at 21:05
    \$\begingroup\$ Please clarify what you mean be "microSD card adapter" - is it one of these? hobbycomponents.com/adapters/… \$\endgroup\$ – Bruce Abbott Aug 27 '19 at 21:25
    \$\begingroup\$ Still unanswerable without documentation of the exact circuitry on board. But you don't need that, it would be simpler to just use a passive breakout. \$\endgroup\$ – Chris Stratton Aug 28 '19 at 1:03
microSD card adapter operates at 5v when connecting to 3.3v of stm32
No, it doesn't. An SD to microSD card adapter is purely a physical adapter -- there is no level shifting involved. SD and microSD cards both operate at a maximum of 3.3V.
(source)
| improve this answer | |
