I am trying to generate power report using Synopsys DC compiler.
At first I have generated VCD file using Modelsim simulator, which I have converted to SAIF file using "vcd2saif" command. Then I proceeded to analyze the power through DC compiler.
However, I am getting an warning " There are 1166 objects not found during annotation", and the combinational switching power is showing zero for my design.
What can be the error?
I believe the internal signals in the generated SAIF file from the MODELSIM does not match with the internal signals of the synthesized netlist. Do I have to perform postsynthesis simulation, but then how to link the design library file with MODELSIM.
Kindly guide in this regard.
