i need change 5v to 12v that it use to supply a device; for this use MC34063A step up voltage converter; this site can calculate the parameter.
i have problem all thinks is OK but i have same voltage at output!
how to find my mistake ?
MC34063A step up
MC34063A step up2
Pin 2 is not grounded so it does not work.
    \$\begingroup\$ ok, Thank you, i check it , now worked. \$\endgroup\$ Aug 29, 2019 at 9:40
