I am wiring a single to 3 phase VFD to a 3 phase motor (240V delta). The 3/4HP motor powers a lathe in a domestic setting. Supply voltage is 240V 50Hz.
As per the VFD instructions, I am using shielded cable (SY 3 core plus PE) between the VFD and motor and have used the motor cable shield clamp at the VFD. Additionally, I plan to connect the earth wire at the VFD and motor.
VFD datasheet: http://www.elektro-trading.com.pl/pdf/napedyac/601/HA464518.pdf
My question is should the SY cable shield also be terminated at the motor? Safety is my priority and I would also wish to minimise electrical noise.
