Let's say I have 1m of 2,5mm² copper wire, insulated with H07V-K. The wire carries 40A and environment temperature is 25°C. The wire is suspended in free air. How hot will the wire get? And how can I calculate it for other values?
The use case is a 12V-230V AC converter I want to hook up to my car and determine the minimum wire thickness required. Because it's only used from time to time and not buried in a wall I suspect I can use thinner wires. This is a temporary thing and doesn't need to be up to code.
