A second-order system has the closed-loop transfer function T(s)=Y(s)/R(s). The system specifications for a unit step input is as follows:
I managed to solve the problem until this step. But I am stuck at solving the permissible area for the poles in the s-plane as per the question mentioned in the given image.
  • \$\begingroup\$ Why are you stuck at this final hurdle. Explain. \$\endgroup\$ – Andy aka Aug 30 at 6:59
  • \$\begingroup\$ Sketch regions of the s-plane that satisfy each of the three criteria, defined by your equations. That will define the region that satisfies all three concurrently. \$\endgroup\$ – Chu Aug 30 at 11:06
