I was trying to make a roaming device which helps me route my calls through the internet, to save on my bills while on international roaming.
My setup is like this:
GSM module SIM800l, Raspberry Pi 4, a USB audio adapter (Quantum-QHM623) and an Android app to get calls redirected.
Basically this setup routes all my calls from my simcard to my phone app via the internet.
The project is almost complete, but the issue I am have is that when the speaker of the SIM800l is connected to the mic of the USB audio adapter, I get a whole lot of background noise.
These are the trouble-shooting steps I followed which might help you assess the situation:
- I can hear the voice with a lot of interference only when I connect the speaker's +ve from the SIM800l to the +ve of the mic in the USB adapter's +ve side. If I connect -ve of the speaker out to the mic ground of the audio adapter, all I hear is noise, no voice.
The other audio line which is mic from the SIM800l to the speaker of the USB adapter works absolutely fine.
I tested the modules this way and they seem to work fine:
Audio USB adapter: to see if the audio adapter is working, I tested shorting out the mic and speaker and simulated a call from the Android app, and it worked fine (I was able to hear own voice after I said something, and the voice quality was good too).
SIM800l: AT commands work fine; I was able to send and receive messages, able to call receive calls and hang them up using minicom.
Audio lines of the SIM800l: I shorted the mic and speaker lines and made a voice call to my mobile number, and I was able to hear my voice fine, but the quality is ok.
Any help with this noise issue would be very much appreciated.
EDIT: I can work around this issue using a different power supply. I had previously used the same Raspberry Pi to power the SIM module, but now I have used a different power supply to power the SIM800l module, and it's working quite well.
Is there any way to use the same power supply and not get the noise?
