enter image description hereWhat is the meaning of having 2 series inverters, one with the switching threshold at 1.025 V and the other with the threshold at 0.3V?
What does this difference between the switching levels mean?
The circuit has a sine wave at the input of the inverters and it makes a clock signal from 1.8V to 0V.
Thank you!
Switching threshold means inverter is working when the input more than threshold (kind a comparator) . So In your circuit 1.035v inverter's duty cycle is %43.5 other's duty cycle is %83.If you want %50 duty cycle you should chose a inverter with 0.9V switching threshold.Also if you connect these inverters parallel they short circuit each other because of phase difference (one is positive when the other negative (or ground))
  • \$\begingroup\$ they are in a series connection \$\endgroup\$
    – tairit
    Commented Sep 1, 2019 at 17:58
  • \$\begingroup\$ Can you add circuit's schematic ? Is it like this : Input>1.035v inverter>0.3V inverter>output \$\endgroup\$
    – Mordecai
    Commented Sep 1, 2019 at 18:00
  • \$\begingroup\$ picture added. Q1 is the signal coming from an quartz \$\endgroup\$
    – tairit
    Commented Sep 1, 2019 at 18:03
  • \$\begingroup\$ I don't want to lose my time for circuit analysis so which ones inverter (1.035v ) and inverter (0.3v) ? \$\endgroup\$
    – Mordecai
    Commented Sep 1, 2019 at 18:08
  • \$\begingroup\$ the first is 1.035v and the second is 0.3V \$\endgroup\$
    – tairit
    Commented Sep 1, 2019 at 18:11
