I’m using a lolin nodemcu 8266. I was wondering if it is possible to connect 5 flex sensors to one node (to make a glove which detects finger gestures).
I’m an experienced programmer but new to electronics.
  • \$\begingroup\$ Are they digital or analog output? \$\endgroup\$
    – Reroute
    Sep 4, 2019 at 2:13
  • \$\begingroup\$ The ESP8266 typically has one analog input, so you'd need an analog mux, or more simply perhaps, an ADC with it's own analog mux. Places like Adafruit sell various little multi-input ADC boards intended for use with the raspberry pi which lacks any ADC at all, that might fit your need. \$\endgroup\$ Sep 4, 2019 at 2:28
  • \$\begingroup\$ @ChrisStratton I just started learning about electronics. Do you have a suggestion on one you would use ? \$\endgroup\$ Sep 4, 2019 at 12:01
