I am planning a circuit that requires two-way communication between one esp32 and 3 others. I want to use a master/slave architecture as shown here: Planned ArchitectureThey need to be able to communicated via hardware, not wirelessly!
Is this possible using the following circuit? 1 (in this circuit, the CLK pins are serial clock pins and the SD pins are serial data pins, i plan to use i2c (which may also need the arduinos to have a common ground...))
Any solutions/ideas are appreciated
  • \$\begingroup\$ What are the functions of these pins? Which protocol are you planning to use? Please edit the question. \$\endgroup\$ – Long Pham Sep 4 at 8:47
    \$\begingroup\$ my apologies @LongPham, question updated \$\endgroup\$ – 3NiGMa Sep 4 at 9:19
  • \$\begingroup\$ How long are the wires? \$\endgroup\$ – Chris Stratton Sep 4 at 14:18
  • \$\begingroup\$ The wires are 20cm (~ 8”) \$\endgroup\$ – 3NiGMa Sep 4 at 21:06
