simple model of a diff opamp with an independent differential signal source
how does current flow through the transistors since V1 and V2 and referenced to each other and not to vee? i understand how the circuit is supposed to work for example in a case where V1 and V2 are each referenced to vee, but need some help to understand figure 1 where there is no reference of the differential ac source to the opamp vee rail.
