I was projecting a simple circuit that, from a digital OUTPUT from an Arduino zero (3.3 V) switch on a BJT that is connected to a relay.
The base of the BJT must have a current of about 5mA or less. Is this configuration enough to run a relay?
I have simulated this circuit and Ic is about 49mA; if I change the relay, Ic increases or it's fixed?
I'm not really good at this thing
