As part of power supply testing we are measuring the current profiles of various regulators.
Startup profiles includes current bursts with different current amplitudes and widths.
i want to understand the accuracy of the current probe*(MINIMUM CURRENT WHICH CAN BE MEASURED ACCURATELY UPTO 1% to 3%)* in measuring currents.
For example in my case, I have TCP0030A current probe from Tek-
it has 2 ranges 5A and 30A.
1. whether in both ranges the accuracy differs or same
It has different specifications like
DC gain accuracy <3%(1% typical) - i am not sure what is this exactly?
Displayed RMS noise <75uArms
1mA sensitivity- Is this directly relates to Minimum current can be measured with this probe
If i want to find the accuracy of the measurement, how i can derive error from all above error sources.
The sensitivity (1 mA) is the smallest current that can be consistently sensed by the instrument, i.e. it is guaranteed that you will get some reading with anything above 1 mA.
The gain accuracy tells you your measurement accuracy as a percentage of the measurement itself, so if you are sensing 1 A you can expect +-3%, typically +-1%.
The figures above are true for a properly calibrated, degaussed, warmed up and auto zeroed probe.
  • \$\begingroup\$ :Thanks. If i measure 1.5A using probe in scope, it means 1.5A+/-45mA (with 3%). Will it be same for whole range (30A or 5A)?I believe the probe mentioned is a hybrid probe which uses transformer for Higher currents and Hall effect sensor for Low currents - even though both are different sensors is the accuracy remains same? \$\endgroup\$
    – user19579
    Commented Sep 6, 2019 at 10:37
  • \$\begingroup\$ That is a question that is answered on the datasheet... If they only give 3% figure both for 5 A and 30 A then yes, the error is the same. \$\endgroup\$ Commented Sep 7, 2019 at 5:48
  • \$\begingroup\$ Thanks. Is there any specific reason behind mentioning the accuracy as "DC Gain Accuracy" \$\endgroup\$
    – user19579
    Commented Sep 9, 2019 at 8:45
  • \$\begingroup\$ Yes, it is gain accuracy only. Total accuracy depends on gain, offset, linearity, noise... Probably there is a tempco as well. \$\endgroup\$ Commented Sep 9, 2019 at 14:44
