I realized that I have a voltage difference of 5 to 80 V AC (orange in Fig. 1) between the protective conductors (grounding cables, "PE-Leiter", yellow-green contacts in drawing) before vs. after a surge protection device (Fig. 1: red box; photo in Fig. 2). Always measured the "permanent" outlet of the surge protection device (green circle in Fig. 2).
The range of 5-80 V results from several measurements (40, 68, 75, 5, 30, 80 V) after dis- and re-connecting the SPD to the wall socket, without effect of connecting a tablet charger or nothing at all to surge protector outlets).
Questions: Is this difference of 5-80 V AC normal? Why is this difference? Am I getting sth. wrong? Possibly result of phase shift b/o "non-Ohmic" elements in surge protector (might skew Null position, but should not affect grounds, right)?? (sorry for my ignorance if this is possible at all)
Additional information: Renting apartment house, 230V AC, TN-C-S network, i.e. Null (blue) and ground wires (yellow/green) are separated in the whole apartment. Load in the whole apartment is currently moderate: a normal household fridge in kitchen, PC + monitor, LED ceiling lamp (all before surge protector), and nothing or tablet charger plugged into surge protector.
EDIT: As suggested by Justme (thanks!), I added measurement of resistances (see updated drawing in Fig. 1), suggesting that the conncetion between the SPD plug and SPD outlet grounds is fine, but not the wall socket ground of spcifically the one wall socket I had chosen for the SPD (Fig. 3)!
Fig. 1: delta-U of 5-80 V difference after surge protector. Dotted lines indicate measurements with multimeter (Fig. 2): Grey, as expected only mV range (esp. between heating tubes and AC ground); orange, unexpectedly high AC voltage difference. The two ground wire contacts in the sockets are in standard position (German "Schuko-Steckdose") and connected to each other. Drawing to upper or lower one only for graphical reasons, no technical meaning. Edit: purple, resistance measurements.
drawing of connections and measurements
Fig. 2: photo of surge protector and used voltmeter. Green circle: clamp used for measurement of ground potential after SPD. enter image description here
Fig. 3: Photo of wall socket outlet where the previous tenant (hope it was not a professional painter) had obviously been very generous with wall paint, adding some (imperfect) isolation to the ground contacts (red circles). Leaving the ground contacts functional would have been more important than all the semi-functional child-proof plug-locks (residual glue in the socket). This is not what I expected and inspected when I moved in in a hurry, new job, lots of things to do. The socket is behind a cabinet, making it hard to see and inspect... Lesson learned. I am glad no accident happened! Probably each dis-/reconnect cycle did or did not scratch some paint resulting in the variable (delta 5-80 V), but still bad connection.
  • \$\begingroup\$ Can you measure resistance from PE contacts between the plug and socket of surge protector, to know if the PE is correctly connected throughout (i.e. wire not broken, or bad soldering etc). Do the measurement when it is disconnected from wall mains and everything else of course. \$\endgroup\$
    – Justme
    Sep 7, 2019 at 8:30
  • \$\begingroup\$ @Justme: Great, I believe your suggestion led to a solution (see edit and new Fig. 3). Can you post this as an answer that I can accept? Would be a great advice for all new tenants to inspect the wall socket incl. grounds for signs of obvious malfunction before placing cabinets etc.. Never expected s.o. to paint and isolate socket outlets... \$\endgroup\$
    – Martin
    Sep 7, 2019 at 10:49
  • \$\begingroup\$ great you found a solution. It was so unexpected that I must add this to my mains safety checklist as well. \$\endgroup\$
    – Justme
    Sep 7, 2019 at 11:00
This is a sign of PE not being properly connected at some point. Check with a multimeter for bad connection or paint residue.
