I want to build a lithium ion battery charger with tp4056 module but most of my power supply's voltage is 12-19 V
Datasheet says input voltage is 4.5-5.5v and current 1A
Can I connect 1-3 tp4056 module in series ?
I think it won't work because voltage drop not constant ( depends on how much module consume )
I thought to use l7805 or lm317 but 1A is seemed too much for them
Right now I'm thinking about using pwm circuit with MOSFET but If anyone have better idea , I want to hear it Also if I make pwm circuit to convert 19V (4A) to 5v , output current stays same or could it be 12A ?
Thanks for helping
  • \$\begingroup\$ You must convert to an acceptable voltage range but why would you need 12A? \$\endgroup\$ Sep 10, 2019 at 0:42
No. They will not share the voltage equally. The one that draws the least current will get the most voltage, then it will blow up and probably become a short, putting all the voltage across the other one which will then also blow up. Don't do it!
It's possible, but very wasteful. A 7805 on 12V has to dissipate (12V-5V)*1A = 7W, which would require a large heatsink to keep junction temperature below 125°C.
PWM alone is not enough. You need something to smooth the output and regulate the voltage. This is called a buck-mode switching regulator. Low cost switching regulator modules are readily available, and are much easier to use than trying to make your own.
The power supply can be rated for any current above 1A, the load will only draw the current it needs. A switching regulator will draw even less current because it boosts current in the same proportion as it reduces voltage.
  • \$\begingroup\$ I have another question about pwm circuit with MOSFET but I should ask another question for it . I can regulate voltage with l7805 (pwm output) Also About current question: For example load is 1 ohm and power supply's voltage is 12v (3A) so if I convert 12V to 5V , will current be 3A or 5A ? Power is same 12V 3A = 36W , 5A 5A = 25W \$\endgroup\$
    – Mordecai
    Sep 10, 2019 at 1:39
  • \$\begingroup\$ With a switching regulator output power = input power - switching loss (eg.10%) so it would draw 25/12 = 2.08A +10% = 2.31A at 12V for 5A at 5V. \$\endgroup\$ Sep 10, 2019 at 2:00
  • \$\begingroup\$ But power supply's max power is 36 W (change load to 2 ohm), So in 5/12 period = 12v / 2 = 6A (72W) and 7/12 period 0w average power 30W ? Also I think I can't make pwm circuit with N channel mosfet because load supposed to be between Vsupply to mosfet's drain and mosfet's source connected to ground but if I do that pwm doesn't work \$\endgroup\$
    – Mordecai
    Sep 10, 2019 at 2:18
  • \$\begingroup\$ You can't use straight PWM on a TP4056. It needs a smooth continuous supply voltage, regulated to within 4.5~5.5V. A switching regulator smooths the current through an inductor and output voltage with a capacitor. Thus we consider the average (not peak) currents at input and output. \$\endgroup\$ Sep 10, 2019 at 2:41
